Old 07-18-2006, 09:59 AM   #6
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
sounds like code 52 which is knock sensor, check to make sure your plugs aren't broken and that (if turbo) both are plugged in (if na) that "the" knock sensor is plugged in
get a piece of wire and you should have to open the lid on the diagnostic box, inside the lid is a diagram of what each pin is, there you should find where te1 and e1 is
if ever you do a diagnostic and you have put the wire in but your check engine light stays lit and doesn't blink thats because the wire has not made firm connection in both of the terminals
Pics of my build.
Do a diagnostic first!
suprra_girl is offline
