Thread: code search
Old 03-24-2010, 01:16 AM   #6
No, not really. The FPR will still work to maintain the same pressure as usual, there may be a bit of a bump, but not much and you shouldn't rely on it as it will be inconsistent. You can use an adjustable FPR along with a pump upgrade, but don't overdo it...
Green, I've copied that code sticky to the MKIII FAQ as well. I'll be adding info to it one of these days...
