OK so in response to the above post,
There is no MODS done to the car at all, plan Jane.
what the car failed for
this is before new wires cap and rotor.
Cruise
HC / CO
150 / 1 Limit
286 / 7.12 Actual
Idle
220 / 1.2 Limit
303 / 4.09 Actual
After cap rotor and wires
Cruise
HC / CO
150 / 1 Limit
274 / 6.55 Actual
Idle
220 / 1.2 Limit
305 / 1 Actual
The air filter hasn't been changed and is dirty but would it screw it up that much? ^^^. If so then I'm a monkey's uncle.
I used a timing light to set the 10 degree on the crank pulley. what is this with a jumper business? so i have done it this way? and how?
there is no engine lights on, so i wouldn't think to check it. (i will ready sticky above).
Shane
