By a different motor I wonder if the seller meant that they put another one of the same engines in it, because you are correct, a 7MGE is a 3.0L Twin Cam 24 Valve engine. Typically the timing belt cover (upper) will have the engine code right on it (7MGE or 7MGTE). Easiest way to identify it would be to post a picture of it.
Since this is a MKIII Specific post, I'll move this thread to that forum for you
