Low Coolant Light= Check coolant level in radiator and reservoir (sensor is in the reservoir)
Brake Light= Check Brake Fluid level, ensure parking brake is not set
Check Engine Light= Check for codes as stated in the MKIII FAQ
Battery Light= Check your connections on your battery terminal, may need to get alternator tested
Brake Lamp Failure Light (Car with light beams coming out the back)= Make sure that none of the 5 brake lights are burned out, you may need to fix the grounds on them as well as this is a common issue
