hello all noble supra guru's. also if this was in the faq i'l sorry i didnt see it, but i am haveing an issue where oil is being pushed out of all areas of the engine (valve covers, oil pan, cam cover and now behind the distrubitor!) could this be a vacuum issue? had to replace my starter because of it being defective! yay advanced auto parts for it being a free replacement
! so as to that being said i have the intake body apart up to the 1st intake assembly. had the head apart to replace bhg. had no leaks before so now after i have this problem that is why i'm leaning toward the vacuum lines getting crossed. it is a 87 7m-ge and i had replaced ALL the vacuum lines ( just some info to give you background on work done) or could this be a sign of something bad on the horizon...
thank you for your time in this matter. Gary.
