Originally Posted by matt1993supraTT
the a/r's (did you mean a/f's?) stay around 12.9 before it dies, its a singal turbo 50mm waste gate stock computer 750cc injectors 255 walbro adjustable FPR and cam gears with the exhaust cam retarded 4 degrees, the guy thinks a AEM will slove his problems but i cant give him a clear answer about, another thing that strikes me as off the maf is on the intake side inline with the intercooler pipes  crazy! its also missing most of its sensors that where on the intake
Which guy? The owner? Is he paying you to work on his Supra?
I agree the maf configuration needs to be changed back to oem - this is a strong suspect as the first troubleshooting step to take. Although an AEM might fix the problem, that's like fixing a cut in your finger by replacing your arm with a robotic prosthetic. A whole AEM setup is $2500+, and this could likely be fixed with a few hours (or less) of troubleshooting with the existing setup.
