Originally Posted by Off Road SHO
Lusiphur,
I'm using the whole rear subframe complete from wheel to wheel. The front is where I am having problems deciding how much angle to build into it's mounting. I'm suffering from the paralysis of analysis syndrome.
Tom
oh duh. i just kind of skimmed your first post. i re-read it. i see what you need. all the same if i get to measure my stuff i'll check the front subframe to see whats what.
just a guess but i think the upper A-arm mounting points to the subframe(the big through bolt) should be level and perpendicular the to ground. i check when i get over to the car though.
