Thread: Coolant plugs?
Old 03-31-2010, 12:47 AM   #10
Green7mgte
Supra Forum Moderator
is it cold only missfire?
The leak may occur only as the engine cools down alter it's shut down, or it may be continuous. Either way, the leaking coolant enters the combustion chamber while the engine is off. This fouls the spark plug, causing the misfire during the engine's first cold start. Once the plug has a chance to clear itself and begin firing, the misfire goes away, but not before the misfire code is stored. If any more coolant continues to leak as the engine warms up, it's burned because the plug is no longer fouled.
I would suggest renting a rad pressure tester or go buy one for 60 bucks from harbor freight. pressure the rad system according to the psi on the rad cap (13 max) and see what sprays!
good luck
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
