The GE injectors are not enough for any appreciable amount of boost... maybe 3 to 4 psi.... What was meant was that even a built up 7M-GE is rarely capable of moving enough air to require larger injectors. That doesn't include N/A-T applications.
So the AFM is new? Does the car choke over 4K regardless of the throttle position or only when floored?
