Shortening the shifter results in decreased leverage making shifts require even more pressure. This is even the case with a proper short throw shifter which moves the fulcrum, if the overall length is less.... wait until you get your shifting issue fixed before you make it worse.
Yes, the bushing is one of a few possibilities... it's the easiest to address and the least expensive, so I'd start with that and see how things go after.
