Old 04-04-2010, 08:25 PM   #6
Originally Posted by Bill UK View Post
I contacted Castrol Tech Dept and they confirmed that Dexton III is a GM fluid, and not meant for the A340 boxes
Whoever you spoke to was asleep at the wheel. The A340E even came with a GM ATF in it.... Dex II. The only Toyota auto's I've found mention of that don't require some form of Dex are pre80's and those use a REALLY old Ford spec ATF known as Type F.
