Originally Posted by Green7mgte
I would search around and ask on acouple different forums the precise question you need answered..
I have a ebay universal IC. what piping route did you use. did you have to CUT anywhere? Ive seen pics of aftermarket ic's were it would normally connect to the 3000 pipe connect to the front engine facing side of the intake manifold. whats up with that? howd you make that work? whats the upsided.. I would like to know these answers also.
post if you find any results.. good luck
I talked ot a guy who said he ran the hot air side from bottom of turbo to the driver side of universal ic with a 180 degree bend to meet ic input, then ran the cool air side back through stock location to the 3000 pipe would that be a good idea?
