if anything, you have mold near the evaporator from the condensation runoff. check the carpet under the dash, then think about takin the HVAC system apart to clean it out to get rid of the smell.
Or cover it up, cause that'll be easier.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
