Old 04-08-2010, 04:17 PM   #4
MA70-3.0GT
MA70-3.0GT's Avatar
Can't put it much better than that, and if the ISCV does turn out to be the prob. it's not always doom & gloom. A fair proportion of the time they're just glued up with old oil & crud & a good clean with brake cleaner spray can sort 'em... For my money though if it's intermittent I'd suspect the TPS (bet the EML comes on when it won't idle, if it works! next time it won't idle do the diag. check before touching the throttle again & see if you get a code 51...)
Last edited by MA70-3.0GT; 04-08-2010 at 04:23 PM. Reason: remembered what code is what!!!
