Thread: 2jz install...
Old 04-09-2010, 04:24 AM   #2
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
Also check around on supraforums as well and 1jz kings, they've got some good information on the swap.
quick note, the r-154 is the MKIII turbo 5 speed, the w58 is the non-turbo 5 speed for the MKIII and MKIV. the A340 is the auto tranny i believe.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
