Sorry, my bad.... another person was talking about the OD and I thought it was you... Obviously not as Manual transmissions don't have an OD light.
The alarm is a common cause followed by a bad clutch start switch (on the floorboard/firewall where the clutch pedal arm presses it when it swings down. I would start with those and testing to see if any voltage is reaching the small solenoid wire at the starter.
