Odometer will be significantly off, same for the speedo (and no, no replacement drive gear for the send is available for the W58 as far as I can find). You'll also lose acceleration, but your highway mileage will increase. Depending on how you drive in the city you mileage may suffer.
I ran a 3.91 from a pre89 GTE on my N/A for a while. I liked it for a commuter but I could definitely tell the difference when I opened it up.
If you're just trying to keep it moving, go for it, but it's not a performance upgrade.... If you just want a LSD then find a 4.30 LSD from a N/A.
