1jzgte no boost???????????????? MAP sensor? You have one?
Guys I seriously think I am not getting any boost. Maybe a tiny bit of boost but I KNOW a 1JZ-GTE should be pretty darn fast. My stocker boost gauge doesn't work either, I am not sure if it is not hooked up properly or its not working cause there is no boost, but it doesnt show a vacuum at idle just stays at 0. I dont hear the stock twins spooling up or getting louder and barely hear the BOV at all. I just had a new fuel pressure regulator put on cause the one I had before was loosing pressure. Do you think this may be my MAP sensor? Heard that from a couple people now. And does anyone know what the ECU shoud look like for it? I am looking at the one in mine and wondering if its the correct one. Car runs great except for no boost. Any tips would be wonderfully helpfull! Also which year does the 2jz-gte map sensor work for mine?
I have an 87 BTW.
THANKS!
87' 7M-GE Custom fab 3" Headers, Cat-Delete, 4" High Flow Flowmaster (WTF!!!!  ) MAF Adapter with truck sized Spectre filter. NGK Laser Platinum Plugs. K&N Oil Filter
87' 1JZ-GTE Truck sized Spectre Air filter, Walbro 255LPH Fuel Pump, GM Fuel Pressure Regulator, Welded Rear end gears, Targa Top, 3" Intercooler kit, aluminium intercooler, Ebay boost controller, Ebay Oil-Catch can, I HAVE POWER STEERING AND A/C :P  K&N 2JZ Oil filter, Catrol Syntec 10w-40 Fully synthetic oil
