Thread: Bhg
Old 04-17-2010, 04:45 PM   #11
btwilson86
Super Moderator
btwilson86's Avatar
Pulling the engine on these cars is fairly straightforward. You can leave it almost fully assembled if you pull the wiring harness with the engine. All you have to do is remove your glovebox, unplug the harness from the ECU, and push the wires and the grommet out through the firewall into the engine bay. Then just find the couple of connectors that go to body electronics, and you're good to go.
IMO, it's easiest to pull the transmission with the engine. Helps maintain the proper angle when removing it from the car, and then you don't have to deal with the PITA bolts at the top of the bellhousing.
And one last thing, remove your hood! First time I didn't think it through and halfway through the process I had to stop to get that thing out of the way
