Originally Posted by Krem
are you getting spark at all? if so, try adjust your timing... if not... at least you know which end of the elec system you need to focus attention on. Also, did you get a new ECU with the turbo? 7mge != 7mgte on several different levels... including compression ratio..
i have power to the coil and distributor but no spark. i changed ECU and harness but still no spark
