Originally Posted by TripleC
What about a boost leak. if they are spooling then they want to Build Pressure. Check for a Major leak...
Found the problem actually. The custom made frame for the FPR was blocking the turning cam thing for the throttle cable so it was only opening 50% OMG!  Got that remade so its not in the way. Now I am definately boosting!
Its not perfect though. I was running 32psi through my FPR and I had the mech turn it up cause it bucks around 4-5k under WOT. Otherwise it does alot better. So now it is set at 36psi, but I was wondering what the fuel pressure should be at. Reading something about 43? If it is running lean would it cause it to do that?
87' 7M-GE Custom fab 3" Headers, Cat-Delete, 4" High Flow Flowmaster (WTF!!!!  ) MAF Adapter with truck sized Spectre filter. NGK Laser Platinum Plugs. K&N Oil Filter
87' 1JZ-GTE Truck sized Spectre Air filter, Walbro 255LPH Fuel Pump, GM Fuel Pressure Regulator, Welded Rear end gears, Targa Top, 3" Intercooler kit, aluminium intercooler, Ebay boost controller, Ebay Oil-Catch can, I HAVE POWER STEERING AND A/C :P  K&N 2JZ Oil filter, Catrol Syntec 10w-40 Fully synthetic oil
