Old 04-22-2010, 03:45 AM   #10
turbonicsperformance
turbonicsperformance is on a distinguished road
i would sure love to see the 900hp dyno test when your finished
until then im not really convinced
search google for brian crowley rods the car they tested on was a 7m gte supra making 1200 to the wheels idk what you all think but 900hp is not that high of a goal making 35-40 psi boost with 1200cc injectors on a 90mm turbo is like running 60-70 psi boost with a 50-60 mm which is what most people run for an aftermarket turbo a 06 evo9 with 2.0 turbo 270 cams 1400cc injectors same rods and pistons that i will run 9-1 comp at 35psi made 850whp and that is a 4cyl 2.0 a 6cyl 3.0 same setup should theoretically make 50% more power that being 425 thats 1275hp that would be a tough goal 900 isnt it will be very easy especially running c16 and 90mm turbo hell the same evo before new build made 675whp with a 60mm turbo 270 cams eagle rods same pistons at 35psi and 1100cc injectors on only a stage3 6 puck sprung clutch
turbonicsperformance is offline   Reply With Quote
