Potential problem areas that come to m mind are: ECU coolant temp sensor, Idle Speed Control Valve, cold start injector or the cold start time switch.
I'm moving this to the MKIII section where it belongs. Check the FAQ in that section for details on testing for diagnostic error codes and post back if you have any.
