Originally Posted by livelaughslide
tourqe specs on ARP head studs
Studs, 90ft lbs... Bolts, 75 ft lbs.
crank em then back it off then crank again?
Only if you encounter striction. This shouldn't really occur is they're well lubed and you've properly chased the threads in the block... at least it is quite uncommon.
Oh and i put number 1 pistion at TDC and put the cams a TDC put the belt on and cranked it 4 times to make sure it was still stright perfect and it is but then i thought.. is everything sapossed to be right at tdc?
I have no idea what you're asking here.
