http://store.driftmotion.com/static/i-tap12x125.php
As for the moly thing... torque values vary depending on the type of lubricant used. Where a fastener may only require 90ft lbs with a good moly used to luge the threads it may require as much as 130ft lbs if only lubed with 30 weight oil.
