Old 04-26-2010, 04:23 PM   #2
MA70-3.0GT
MA70-3.0GT's Avatar
so you're getting fuel back through the return line as well? Just a thought but if you have no access to a fuel pressure gauge (think 30psi is correct if you do) then just as a precaution change the fuel filter in case it's drawn up the crud from the tank bottom & clogged resulting in low pressure.
You could also use the tsrm diagnostic function to check for fault codes and this would be the simplest & most sensible start really-: your new best friend
pull the codes, if any & find what they mean. If you have no joy there then the fuel filter would be next on my list if it just happened after running dry. Best of luck, let us know either way.
