Originally Posted by mrgdm007
Very detailed!!! Transmission or Clutch Problem
OK I have a 1994 supra tt 6 speed, I bought it about 3 weeks ago from a toyota dealership. The clutch has just been replaced and the flywheel had been re-machined. My problem is that I will be driving in 1st gear and and 2nd gear when I push the clutch in there is a reasonably loud chatter that you can hear from inside and outside the car even if your standing 10 feet away from the car that happens about three times,( clutch in, chatter, chatter, chatter) then it stops.
I also have a problem with when shifting normally into 2nd and 3rd gear it feels like something is hitting it, almost like the clutch isnt down all the way down but theres no grinding just a bump and it goes it to gear. If im driving though and lets say I take it out of first, wait a sec or two, and then put it into 2nd gear the bump is gone.
Another thing that happened a few days ago while I was driving I went to put it into 2nd while rolling at a low speed, the gear started to grind, so I moved the stick up but kept it to the left (in between 1st and 2nd) and pulled it down again, it did the same thing and the gears started to grind so I pulled the stick back to the neutral position (between 3rd and 4th) and then pulled the stick to 2nd and it went right in no problem, the thing that didnt make since to me was that my foot had the clutch down to the ground the entire time from the low speed roll to the transmission going into 2nd gear. If anyone could help that would be great!
i wonder when they machined the fly wheel if they cut it down too much!? i had a 1g AWD talon a few years back and it happen to me machine shop took to much off the fly wheel and the clutch would chatter and would also grind when trying to put it in gear where thats a DSM & we're talking about a supra not sure if that helps
