I would say you have a bed fuel level sender, it is corroded or the fuel level float is stuck at the top.
I have a similar problem with my car, If i put put a full tank of gas in it, the needle will go to 3/4 tank and then slowly sink down to a little over 1/4 tank. I have never taken it apart to pinpoint the cause. It could possibly help to go after the connecter for the sender with some CRC qd electrical connection cleaner. I do not know myself if the connector for the fuel pump and the sender are in the same harness or not.
1987 Toyota Supra 7MGTE AUTO
1987 Toyota Supra 7MGE MANUAL
1990 Toyota Supra 7MGTE AUTO-> MANUAL
