Old 04-28-2010, 07:09 PM   #1
Supra_Freak_7m
Supra_Freak_7m's Avatar
Supra_Freak_7m is on a distinguished road
Oh, I thought you had an auto, i saw when you said fifth gear too i just thought it was a typo. In that case i have no idea what would cause the car to die between shifts. i think the first thing to do is make sure you dont have a diagnostic code stored in the computer indicating possibly a bad sensor (MAFS, TPS).
Check your connecter on your MAFS and make sure it is not loose
Also, check your negative battery cable, make sure it is tight and clean at both ends. The cable should be grounded to the block on the driver side pretty much directly above the engine crossmember. If you have to remove the bolt that holds it on, dont worry it is a dry hole, neither oil nor coolant will come spewing out of it
try those and see if that works
NOTE: there are instruction on how to do a diagnostic in the FAQ
1987 Toyota Supra 7MGTE AUTO
1987 Toyota Supra 7MGE MANUAL
1990 Toyota Supra 7MGTE AUTO-> MANUAL
Supra_Freak_7m is offline   Reply With Quote
