OH!!!! Okay... I'll I have worked on is 7mgte motors....
With the distributor being a tooth off i can see why it would have to be turned to start...
And moving the distributor while the engine is running can give you a good way of steadying out the rough idle.
Keep the distributor when it is to start it, and when its running play with it to see if you can get the idle to calm down a little bit.
Along with the suggestions the guy before me said.
89 mkIII turbo supra stick black w/ maroon interior!!!
