Originally Posted by cre
details on how to check diagnostic codes is posted in the FAQ
Originally Posted by jtown125
I don't have a reader I said that
Alright, a little bit of clarification:
I believe cre meant to type "BOV" and not "BOS", referring to an aftermarket Blow Off Valve.
Checking codes on MKIII Supras does not require the use of a code reader, just a jumper wire or a paperclip. As stated above, details on how to check codes are here in the FAQ. Once again, keep in mind that just because the CEL is not on it doesn't mean that there are no error codes stored.
When you do the 4-N and 5-N shift, will it still die if you accelerate at partial throttle without boosting? Does it do it under half load? Full load?
Also, does it cut out regardless of what engine RPM's you shift at (lo vs hi)?
