Check for and post codes FIRST.... then reset all you want. FYI, there's nothing but minor trim data recorded in the ECU, unless there's another significant problem elsewhere resetting it shouldn't make a noticeable difference.
I'm thinking it may be a bad IDL switch. (codes 51)
