Well this weekend I had some spare time and jacked up the car again for round 3.
the car won with a huge crack in the subframe!
I dont have a pic yet but It's about the same size if not a bigger gap and place as yours pictured above where the shaft meets the diff. =(
Is it possible to repair? I belive this is why my diff mounting bolt holes dont allign, and creates the clunking noise when not under load.
I'm planning on dropping the subframe and welding the crack hopfully everything will align if it's solid again? or should I hold out for another subframe?
Tripple C, what are you going to do about yours?
