Originally Posted by jdmsoup
have you checked your fuses and your fuel pump to amke sure its getting fuel?
Fuel pressure check said fuel checked out.
There are a lot of things that it could be. Try using the search option to find more information.
Pull one of your spark plugs, plug it in and hold it against the engine block while someone cranks the engine. There should be a spark. If not, it has something to do with your igniter or distributor or something.
But again, try searching it.
