I agree. Change the fuel filter, and put some sea foam in your tank... its kinda bad for your gaskets and stuff but if you have that much gunk in there i would say clean it as much as you can. When you do take the filter out, check how much gunk is in there. When i changed mine, i knew i had a problem. I dropped the tank and it was rather rusty :/ just give it a good clean and a REALLY good dry and put some Stabile or Sea foam or water removing agent in there with your next tank of gas. Good luck!
