There are a few options but rebuilding your 7mgte is probably the easiest and least expensive if you do it yourself. Yes the 1jz and 2jz will work. The 1jz is said to be much easier and less expensive than the 2jz though. The main thing is that if you reabuild you current motor you will know what is in it and the 7mgte is still a very good motor. If you seach you can find all the the info you need.
