There's no way in hell with adding that and the mods you already have that you'll be close to 500 whp. The stock CT is only good for about 350 whp. And they do make upgraded CT's they have a 57 trim which is good for around 400 whp and they have a 61 trim which would probably be good for what you're shooting for. But in order to accomplish those numbers you'll probably going to want to get a MAFT pro setup or something along those lines. I don't even think a 7M with a LEX AFM can flow enough air to make 500 whp. To make that much horsepower you're looking at quite a bit of money, and a 500 whp 7M is not going to be very reliable unless you get it tuned very good and a professional tune is going to be quite pricey as well. So do your research and you'll find that you're looking at a lot more work than you think to make those kind of numbers.
