Originally Posted by tak2099
Yes the coils and wires are hooked up correctly. Ok, so I wired the stock tps back up, and modified my 80mm TB to use the stock one. Now it does go past 1800 rpms, BUT it still cuts out, but now its random. At WOT it goes just fine, but under normal driving it will randomly cut out. Do you guys think maybe my tps isnt adjusted right? Or maybe if my timing was off it could cause this? Or are both of those not things that would cause a random shut off?
I would start with the timing.. Take the 7mgte cover off, and check it with the timing gun... the numbers, letters should be right stationary when you check it... hope i could help...
carlos
