#1 - Yeah, most likely it's just a broken cable... hopefully the less expensive lower half which runs into the transmission on the passenger side.
#2 - If it occurs whether you are coasting or on the gas it is probably the center carrier bearing in the middle of the drive shaft.
#3 - "Will a Double Din Headunit fit straight into these?" - Yes, no "kit" needed.
