Originally Posted by nfa_automotive
No the head gasket is just something that happens on a 7M.
And it might not be the oil pressure gauge. Sounds more and more like a spun bearing. Oil pump might be dead.
Do some more recon and let us know. Easiest way to check for a oiling problem, pull one of the cam caps off, if they look scared, if they are your going to have to pull the motor apart and see what failed.
thanks for the info ill be rippin off the head in about an hour ill take pics of what i see.
