Old 05-11-2010, 03:53 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
As stated, the engine removal is easy. Only thing I do differently than supraflymkiii is I remove the glovebox, unplug the wire harness from the ecu, and push the plugs through the firewall (with the grommet). This way you can leave the intake intact, and just disconnect the couple of wires that go to the body. Also makes reassembly easier, IMO
