Old 05-11-2010, 07:45 AM   #20
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by mrgdm007 View Post
I cant remember which one the mechanic said but he said since he was taking out the tranny he suggested I might replace the slave cylinder, and he said if I look to get an aftermarket pressure plate or clutch that it would handle the extra pressure, so I would just get it out of the way now
First rule of maintenance - if it ain't broke, don't fix it. *shrug* To me, that's strike one against this 'mechanic'.
P.S. I've seen the mount point for the clutch fork get broken in the past, and could fit with your description of symptoms. This problem can be verified via the inspection port (i.e. without transmission removal).
Life begins at 30psi.
