Fan and Radiator Removal
Is there anything I need to note before I start the radiator and shroud removal.
Also, Should I try and drop the whole exhaust system from the header back to the rear muffler or should I separate it at the catalytic converter.
I suspect that it is better to remove the nuts at the differential and take down the pilot bearing to remove the drive shaft as one unit. Right?
