Originally Posted by supraflymkiii
Check your coil!!! Double check your timing marks and make sure your wires are on in the right order. Most misfires are very simples fixes.
coil is good. spark tested that and its got consistent spark, wires are most definately in order i checked it 132-098 times, timing...doing that today and im checking wiring to see if any wires are bad
but its not just a simple misfire, it sounds like its just running on 2 cylinders or summin.
