I am so stupid
I have to do research just to keep up with your responses. If it is arcing I should be able to see it in the dark correct? I agree I don't think it would idle so well if it jumped time, It will take me some time to figure out the other parts you spoke of. You think that sound is an arc? Wow what a concept! I saw a post about lining up the cam gear. Now if I can figure out where that is on the engine. If I have let this car sit so long because of a bad plug wire I am going to cry.... Thanks so much!
