The front electrical connection to the round canister on the side of the throttle body is the TPS (Throttle Position Sensor). You don't need to remove it, just unplug it. To get to the two lower bolts on the "Y" pipe (as it is commonly called) you need to remove the two black metal brackets and then use two extensions to reach them. An extension with a "wobble" built in helps get a better grip.
The part they're saying to pop off with a screw driver is the rod which runs up the the throttle pulley/lever on the side of the throttle body.
