Not true you can replace the egr cooler with a gasket with the engine still in the car. it will probably be tricky to get the gasket material scraped off the head but it can be done. But it does sound lke the egr cooler is leaking. If you want to do block off plates its recommended that you get a jdm ecu. otherwise you might as well get a new egr cooler gasket.
