If youre going to use air to clean stuff out do your cleaning first then blow it out but if you use wd40 then try to blow it out its not going to work because the shit will be stuck in the wd40. I wouldn't recommend using wd40 as lube for assembly but it will be good to keep stuff from rusting. If you're going to put a mhg on your engine and its out of the car you might as well have it decked so its perfectly smooth. it will save you time and money in the long run.
