boost problem
ok so leme start i replaces plugs and wires. replaced intake tube. checked for leaks cant seem to find any. my problem is if i slowly give full throttle i boost great but if im on it hard it boosts half way up the rpms then feels like it starts to miss. at idle i smell fuel and it spudders every 3 seconds not a misfire spudder but like a blank spot hard to explain more like grrrrrrrrrrPgrrrrrrrrPgrrrrrrr if thats understandable. also if im quick shifting under full throttle it falls as soon as i shift gears and hit throttle again there is a noticable miss but instantly comes back. only throws check engine light if im on it hard. any ideas??????
